ArubaOS and Controllers
built in netdestinations
I am looking to simplify my config and one area is in the acl for management of the controller
Right now we define the controllers as netdestinations but I know that mswitch and controller exist, but I dont know what the difference between them are.
A show netdestination shows them as the same IP address (loopback)
are they interchangeable?
Are there other built in netdestinations?
Aruba System Defaults
They are interchangeable.
The ArubaOS 3.4.1 User guide, Appendix C has Aruba System Defaults that has all the default system policies, ACLs, etc.
