ArubaOS and Controllers
can't load heat map data error
We recently upgraded our 3400 to OS 3.3.3.5 and now get the following error when trying to view maps:
Can't load heat map data: can't load probes: Table 'gapdb.global_radio_table' doesn't exist
Any ideas?
Thanks in advance,
Mark
Re: can't load heat map data error
You should call support...
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
fixed
upgrade to 3.3.3.6 fixed the problem
