ArubaOS and Controllers
controller x has not responded. The process is going to wait 2 minutes before display
Hello all,
I have a master and a backup controller.
When I click on "all WLAN Clients" under "monitor" in the GUI, i first get the message "the master controller is collecting information from local controllers. Please wait...".
After a few seconds i get a message: " 50 percent done..Controller x.x.x.x has not responded. The process is going to wait 2 minutes before displaying results"
After 2 minutes, when i click again on "all WLAN Clients" i get the results.
My backup controller is up, and i can cannect to the GUI of te backup contoller.
i'm using OS 5.0.3.1 and before i used version 5.0.2.1 In both versions i've had this issue.
Does anyone has a idea about the cause of this?
Jan Roelof
Re: controller x has not responded. The process is going to wait 2 minutes before display
Please open a case so that they can attempt to replicate your issue and file a bug. This feature is not used often so it could use another look to ensure it works as it should.
