ArubaOS and Controllers
crashing dual M3s when allowing Control Plane
Upon configuring Control Plane Security and allowing for automatic cert/auth of all RAP2s, having a backup M3 without the cert installed causes the Master M3 to slow down and crash. Don't know how to synchronize the cert. Single 1gbps ethernet cable per M3 , VLAN1, VRRP
Re: crashing dual M3s when allowing Control Plane
If you even think there is a crash, please contact support immediately.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
