ArubaOS and Controllers
Regular Contributor I
destination based rate shaping ?
Hi All,
Is there any way the controllers can do destination-based (IP, network, subnet) rate shaping? I'm pretty sure the answer is no but I wanted to make sure.
Thanks!
MIke
Re: destination based rate shaping ?
Cannot do that. You are correct.
