ArubaOS and Controllers
Regular Contributor II
easiest way to clean up the configuration
When we first deployed Aruba, we did a mirror image of our old WLAN. After moving everyone off of the old SSID to new ones. I want to know what is the easiest way to get rid of the old settings related to the old SSID with all the settings that is related to it.
Contributor II
Re: easiest way to clean up the configuration
I would save the current config file to an external destination using FTP. Then I would cleanup the config and make sure everything is still working. You should get pretty far with some common sense and guesstimating:)
