ArubaOS and Controllers
Contributor I
guest users not shown on guest provisioning after upgrading firmware
We did an upgrade from Aruba 3.3.2.12 to 3.4.2.1. The guest provisiong page is still working and we can create new guest accounts here. These can be managed later.
However, we have a number of guest accounts created under 3.3.2.12. None of those is shown on the guest provisioning page. They are all still working and can be managed using the intern database.
Is there a way to solve this?
Regards
Dirk
Contributor I
Re: guest users not shown on guest provisioning after upgrading firmware
BRW, this is an Aruba 2400.
Regards
Dirk
Guest provisioning
Vieregg,
Starting in ArubaOS 3.4.1, only guests created by an individual "guest provisioner" can be seen by that guest provisioner when logged into the guest provisioning screen.
What this means is if you login to the guest provisioning page, you cannot see guests unless they were created by your login. If you login to the controller with administrator or root rights, you can see them all in the internal database.
Contributor I
The guest provisioning user is the same as on 3.3. So I would guess this account can see all the old entries as well. But this isn't the case.
Not the case
You are correct - this is not the case. In the user database it is now stored what user created what guest users. In the older guest entries, that filed was not populated so moving forward, older guests cannot be seen by that guest provisioner.
