ArubaOS and Controllers
Contributor I
heat map looks strange after upgrade
Recently, we upgraded from ArubaOS 3.3 to 3.4.2.1 Now the heat maps look very strange. This is not true for the ground floor but for everything above.
Is this a known issue of 3.4?
Regards
Dirk
RF Plan Garbled
Regards
Dirk
I heard that this was fixed. If you open a case, they can tell you exactly what release you would need to install to obtain the fix.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: heat map looks strange after upgrade
Happens also here with 3.4.1.1. Know if 3.4.2.3 has all fixes for all sites ?
Thanks, regards
Alex
Alcatel-Lucent Enterprise Italy
