ArubaOS and Controllers
integrate with Aladdin (token) by using certificate.
We have a problem when integrate with Aladdin (token) by using certificate.
We have test with one time password, the result is ok.
We have test with 802.1x (username/password), the result is ok.
We have test with certificate, the result is ok. But if the certificate is expired, client still using that certificate. So I am not sure what could be wrong in the configuration?
Attached file is the configuration, please help to verify.
PS: AOS version is 6.1.0.x.
Re: integrate with Aladdin (token) by using certificate.
Does Alladin check to see if the certificate is not expired? Does it have any way of notifying the Aruba controller when it is expired?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
