ArubaOS and Controllers
Contributor I
new AP connecting to wrong controller
I have trouble configuring an AP since it connects to the wrong controller. We have an A2400 (aruba-master, 10.9.0.200) and an A200 (aruba-test, 10.9.0.202) running OS 5.0.1.0. The AP61 has been used before.
Now I purged the configuration of the AP61 and connected it to the network. Although the default configuration has aruba-master as servername, it always connects to the A200. Even setting the serverip to 10.9.0.200 doesn't change this.
We are not using any white lists so far. This is the first time I connect an AP to our WLAN after upgrading to OS 5. So if something has changed that leads to this behavior, please let me know.
Regards
Dirk
Ip address of the AP
What is the ip address of the access point? Is a controller providing DHCP to the AP, by any chance?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: new AP connecting to wrong controller
The AP is going to use ADP (multicast) before DNS. The AP will associate itself with whatever controller responds to that multicast first. Perhaps this is what is happening in your case.
Contributor I
The AP doesn't have an initial IP address. It will get it by DHCP. However, the controller is not the DHCP server. This is done by another machine on the network.
Regards
Dirk
Contributor I
Ah, I see. Just read about that in the OS 5 user guide.
Regards
Dirk
Log into the AP 61 and input these commands
set master 10.9.0.200
set serverip 10.9.0.200
save
reboot
it will take controller config statically...without looking into ADP,DNS,DHCP....
EMH
What is the order of steps that an AP goes through to discover a controller, and has the order always been the same?
Thanks!
MVP
Thanks!
An AP's master discovery order
1) “master” parameter set (manualy) on the AP
2) dhcp option 43
3) ADP multicast & broadcast
4) DNS lookup for aruba-master
And yes, always been the same.
Koen (ACMX #351 | ACDX #547 | ACCP)
AP connecting to the wrong box.
We are exoeriencing something very similar. When we plug a FD ~AP into the network. It gets its DCHP address, runs ADP and comes back with the IP address of a Fortinet Firewall.
The AP then tries to set up its PAPI tunnel but can't, obviously as the Firewall will neither allow it or want to create a PAPI with an AP.
Any Ideas? Does the Fortinet use a similar protocol to ADP? (Why would it???)
We have searched our DNS entries and there is nothing in there that points Aruba-master to the fortinet IP.
Weare also running SW v.5
tweet @wjhphoto
Console output
Can you post the console output of that AP?
