ArubaOS and Controllers
really easy question....which firmware to pick
I'm downloading V5.0.3.2 for a customer with a 6000 controller, the problem i have is i dont know which one to download from the Aruba site...
Is it the one for "ArubaOS image for supervisor modules SC-I and SC-II"
Or "ArubaOS image for 3000 series controller and M3"
Re: really easy question....which firmware to pick
What supervisor card is in the 6000 controller? If it is an M3 supervisor, then the "3000 and M3" image. If it is a supervisor card I or Supervisor Card II, it would be the first image you mentioned.
