ArubaOS and Controllers
strange AP coverage drawing in RF plan
i have a problem when viewing the RF coverage of the AP from the controller WebUI
i attached the picture,
i have two AP's on AP65 and one AP 70, but the drawing shows as if they use a 180 directional antenna not an omni directional antenna i.e. their coverage must be a circle not as shown in the picture
anybody would tell me what's wrong?
thanks in advance
Web UI
thanks in advance
RF Plan coverage visualization is a function of how many datapoints are available. The fewer datapoints, the less accurate the diagram. At minimum, you should have 3 APs that can all hear each other. If you put only Omnidirectional antennas, can all APs see each other? If not, they will probably have a blue diamond around each other and will not be able to draw coverage accurately, or at all.
With that being said, there are a number of factors like affect patterns being drawn like RF scanning needing to be on. You might want to open a support case to make sure all of those settings are in place to get you the best visualization possible.
