ArubaOS and Controllers
using LDAP for MAC authentication
is any one using LDAP to do MAC authentication for the Apple Iphone or IPAD? seems that i cannot get the Iphone/IPAD to authenticate using the LDAP. we use the internal database now but need to move to LDAP for Global mac authentication.
LDAP for mac authentication
You can do this. Make sure that the mac authentication profile assigned to the AAA profile has the CASE and DELIMITER that match the case and delimiter you have your mac addresses stored in your LDAP database. The MAC would be the username and password in LDAP.
Colin Joseph
Aruba Customer Engineering
