ArubaOS and Controllers
using captive portal example, xml error
I'm using the captive portal example to model a php file that has some paramters hardcoded to test the controler we are deploying.
When I send XML to the controller we see the following below, we are of course substituting a know good username and password when we press 'Accept; button. Any thoughts on this error?? We are stuck and need to move it into prod.:
HTTP/1.1 200 OK
Date: Mon, 11 Jul 2011 20:41:27 GMT
Server:
Connection: close
Transfer-Encoding: chunked
Content-Type: text/xml
Error
3
unknown external agent
19
auth redir 2
0
GET / HTTP/1.1
Re: using captive portal example, xml error
That normally means that you do not have the device sending the XML as an XML-API-Client.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
re: using captive portal example, xml error
thanks. so we need further config on the device we are trying to auth from. i'll get back later and let you know outcome.
No, the controller has configuration for XML-API that determines which devices it will accepts requests from. Please see the XML-API documentation in the user guide.
thanks, much appreciated.
i'll look at the documentation and get w/the network guys.
