ArubaOS and Controllers
validating identity problem
I'm an Aruba newbie getting familiar with the 3200. I have 802.1x authentication setup using MS NPS. I can test authenticate to NPS. I have a CA with trusted cert on test laptop. I have .1x set up Aruba AAA profile for machine autheniicaton and have created a gpo to push to client. The problem is that I get a "validating identity" on the client and no dhcp assignment (dhcp is external). I'm watching realtime stats on NPS and the machine is logging but not connecting. The event viewer security log is showing no audit failures. I think I have misconfigured the controller and i just can't pin down what the problem may be. I've been reading the UG and this forum for a few days and can't come up with a solution. I have a ciisco 5500 with 100 APs at another clients with a similar setup but I think I'm just to new to the aruba setup. Any help appreciated.
Re: validating identity problem
On the commandline of the controller, type "show auth-tracebuf". If you have a radius server and it has a certificate, you need to make sure that the client trusts the certificate. To test this, uncheck "Validate Server Certificate" on the PEAP settings for the client and see if it goes through.
Colin Joseph
Aruba Customer Engineering
telnet problem
I can't enable the console through telnet to run the command. Will not accept the root account password..
Telnet access is disabled by default on Aruba controllers. You have to either connect it via sshv2 with username/password, or enable telnet access.
Telnet option ussually found in Configuration ->General screen on webui.
to do the show auth-tracebuf (mac of laptop), you first should enable debugging for the mac address
logging level debuging user-debug xx:xx:xx:xx:xx:xx
i already had telnet enabled but when i type in "enable" my admin (root) password does not work. Same thing with SSH.
is the debug command through the gui or cli?
Debug command
The enable password on the controller can/and usually is seperate from your admin login password. Maybe its at the default of 'enable' ;)
FYI, the command provided earlier in the thread is from the controller's command line.
problem is: in order to run the command I need to successfully enable the console. i used the admin account password, which is the only root account on the controller. I tried enable has password... nothing. Any ideas?
Do a password recovery...
Console cable access to the controller is required to execute. Resetting the root account will reset the enable password so you can get in...and make progress with the issue at hand.
Here is the procedure:
Login: password
Password: forgetme!
(controller) > enable
Password: enable
(controller)# config term
(controller) (config)# mgmt-user admin root
Log-out of this session, then re-login using the admin
account with your new password.
FYI, The enable password is reset during this process to "enable."
did a pw reset on console so moving forward with the debug...thanks and stay
ran sh auth. cap attached.
the client i'm directly testing with is ltenger
