vlan-name problem
I've never used named vlan before and now when I trying it out I can't get it to work.
Background;
2 controllers, 1 master and 1 local. Today they use 2 different VAP's because AP's terminating on controllers with different VLAN ID's for example the guest network.
So what I did, first in master (VLAN's was created long time ago);
vlan-name guest
vlan guest 1519
did a wr mem so the vlan-name synced to the local.
Then i mapped the 1529 VLAN in local;
vlan guest 1529
Then I changed the VLAN to guest in the VAP. Another wr mem.
When I check in the local controller for profile errors I get this;
wlan virtual-ap "GUEST-VAP" Named VLAN "guest" is not mapped
But, if I do the show command in local for vlan mapping it looks ok;
Vlan Mapping Table
VLAN Name Pool Status VLAN IDs
guest Disabled 1529
There is no profile errors in the master, and I'm using that named vlan for the VAP and it works fine.
Using ArubaOS 6.0.0.1
Re: vlan-name problem
Make sure that VLAN number exists in the local controller (show vlan status).
VLAN name is case-sensitive, make sure it matches in both controllers.
That's all I have :(
The VLAN number exists in the local;
1529 10.152.9.2/255.255.255.0 Enabled Up 1 Disabled Regular GE1/8 N/A
And yes, the name matches in both controllers, only used lower case.
Please look at the knowledgebase article here: http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=904
