ArubaOS and Controllers
Contributor I
while trying to upgrade controller 3400 from ArubaOS 6.1.3.5 to controller OS ArubaOS_MMC_6.2.1
while trying to upgrade controller 3400 from ArubaOS 6.1.3.5 to controller OS ArubaOS_MMC_6.2.1 i am getting the following error
"Restricted Filename encountered." How to resolve this issue?
Re: while trying to upgrade controller 3400 from ArubaOS 6.1.3.5 to controller OS ArubaOS_MMC_6.2.1
Just in case make sure you removed any unneeded files in flash :
- delete filename logs.tar ( if you need this information upload it to your PC)
- delete filename backupflash ( if you need this information upload it to your PC)
Also try upgrading to another partition .
What version AOS6.2.x you are trying to upgrade to?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Aruba
Are you trying this from the WebUI or CLI? And what method?  FTP/TFTP/SCP/Local File?  If you haven't tried already, try from the CLI:
copy tftp: x.x.x.x ArubaOS_MMC_6.2.1.4_40075 system: partition [1 or 2]
Also, Is  ArubaOS_MMC_6.2.1 the complete filename you tried to upload?   I've seen it work with truncated image names, but try keeping the full name of the file to see if that helps.  For example, 6.2.1.4 is ArubaOS_MMC_6.2.1.4_40075
AMFX | ACCX | ACDX | ACMX
Contributor I
The mentioned files are not available.
Contributor I
Contributor I
i remamed the files and tried from CLI and it works with the filename that you gave
Contributor I
I get an error
File copied successfully.
Saving file to flash:
Error upgrading image: ERROR : Need more space in /flash for image upgrade, please clean up the /flash and try upgrade again
(Amaintit-Local) #show image ver
Partition        : 0:0 (/dev/hda1) **Default boot**
Software Version : ArubaOS 6.1.3.5 (Digitally Signed - Production Build)
Build number     : 35523
Label            : 35523
Built on         : Fri Sep 28 08:01:08 PDT 2012
Partition        : 0:1 (/dev/hda2)
Software Version : ArubaOS 6.1.2.3 (Digitally Signed - Production Build)
Build number     : 30182
Label            : 30182
Built on         : Sun Sep 11 12:39:02 PDT 2011
can i delete the file on the partition 0:1? and how to delete the file on the flash?
Aruba
The upgrade needs about 60MB free from the CLI or 75MB from the WebUI.
show storage to see the free flash space available.
If you need space you can remove old logs, crash data and backups.   See the section on Memory Requirements in the Release Notes for details.
