ArubaOS and Controllers
why can't my ap work normal
when i consoled in it , it just stoped in Loading: ICMP Host Redirect to, why it stoped on this state it's ap 92
Re: why can't my ap work normal
Please try to press enter so that the bootup can continue.
No, there is no chance to press the enter, after that it prompts
*** Reboot caused by watchdog timeout. ***
and then reboot again.
What version of code do you have on your controller?
It's ArubaOS (MODEL: Aruba3400), Version 6.1.2.2.
Did you try another access point?
Yeah,now it's ap-105.And it's in the same situation.
Please open a support case.
Ok, anyway thanks for your answers
