ArubaOS and Controllers
wireless clients can't communicate with each other
Customer running IOS 6.1
Wireless clients can't ping each other while connected. Wired clients can ping wireless clients.
The User Role for the wireless clients is set to allow any.
The are all on the same VLAN.
The VAP configuration has the 'Deny inter user traffic' is UNchecked.
Not sure what would be preventing wireless users from communicate with each other.
No device fw are enabled.
Am I missing some configuration option?
Re: wireless clients can't communicate with each other
Look under Configuration> Advanced Services> Stateful Firewall. Ensure that Deny Inter User Bridging is unchecked. That would override everything else.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Ping one device and type "show datapath session table " to see if anything is denied. Also make sure that if broadcast filtering is enabled in the VAP, that Broadcast Filter ARP is ALSO enabled.
