ArubaOS and Controllers
wlsx/wlsxN traps? What's the difference?
Hi everyone,
I'm going to configure internal snmp-server of our aruba controler. I would like configure traps but I have a question.
There is multiple traps that can be the same, example :
- wlsxVrrpStateChange
- wlsxNVrrpStateChange
I read the AOS Mib Guide and there is no diffrenece between them (they return the same thing). Does anyone know the diffrence between wlsx.. and wlsxN... traps?
Thanks in advance
