Campus Switching and Routing
็How to config LACP on Aruba 2930F 24G 4SFP Switch (JL259A) Connect HP A5500 HI
Dear all
       i have project implement network for customers . i not sure my configure corrected. please help me to verify command.
 Aruba 2930F LACP and trunk allow vlan 10,20,30,50 native vlan 1
 #Trunk 1-2 Trk1 lacp
 #int trk1
 #untagg vlan 1
 #tagg vlan 10,20,30,50
 HP A5500 HI LACP and trunk allow vlan 10,20,30,50 native vlan 1
#interface Bridge-Aggregation 1
#link-aggregation mode dynamic
#quite
#interface g1/0/1
#port link-aggregation group 1
#interface g1/0/2
#quite
#port link-type trunk
#port trunk permit vlan 10,20,30,50
Re: ็How to config LACP on Aruba 2930F 24G 4SFP Switch (JL259A) Connect HP A5500 HI
Greetings!
The configuration appears essentially correct for both devices, though if untagged VLAN 1 will be carrying any traffic across the link, don't forget to include it in the A5500's Bridge-Aggregation configuration:
port trunk permit vlan 1,10,20,30,50
port trunk pvid vlan 1
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
Matthew Fern,
  thank you for your support. i have second question ,Please help me  design spanning tree mode for implement , i think use stp mode MSTP for solve the problem, what the best way for choise stp mode ? and excemple command guide for implement .1232444.JPG
My recommendation would be to follow the guidelines in Chapter 5 of the Advanced Traffic Management Guide for the 2930F, as well as the 'Configuring spanning tree protocols' section of the 5500 Layer 2 LAN Configuration Guide (page 63; MSTP section starts on page 70). Unless you have a compelling reason not to use MSTP, that would be my recommendation.
For the Xyzel switch, refer to the manufacturer-provided documentation for MSTP configuration, if applicable.
Matthew Fern,
  thank you for good support .  if i have problem i well call your support again .
