Campus Switching and Routing
16.02 Tunneled-Node per-port presentation
Hi All,
Recently in the new ArubaOS-Switch 16.02 firmware, the Tunneled-Node Per port feature was introduced.  Attached is a presentation by the HPE Aruba Campus Switching TME Team that provides further investigation into Tunneled-Node per-port, best practices, how to configure it, and how it can unify policy enforcement within the network.
Justin
Super Contributor I
Re: 16.02 Tunneled-Node per-port presentation
Hi!
Is there a requirement on firmware version on the controller? I´m running into issues, we´re running ArubaOS 6.4.4.6 on the controller.
I see the tunnel forming from the switchport to the controller but when checking the datapath tunnel I can´t see any decaps on the tunnel coming from the 2930F port.
We have a working MAS S1500 installed which I believe confirms the configuration of the controller is correct.
Any ideas?
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
6.5+ on the controller side .
Tim Cappalli | Aruba Security
Super Contributor I
Hi!
Thanks for the answer, do you know if there´s any plan for implementing support for this in the 6.4.4 train of code? This customer can´t run 6.5 as of now.
Cheers,
