Campus Switching and Routing
Occasional Contributor I
2540 Stacking?
I'm wondering if its possible to stack our 2540s? All we're looking to do is manage the switches with one IP address, switches would be connected together via 10GbE SFP. I'm not finding much in the 2540 documentation and the commands available to the 2530 do not appear to be the same as the latest 2540 firmware. Is this just not possible?
Re: 2540 Stacking?
Hi, afraid it's not possible on the 2540 series. If you can move up slightly in price range (assuming you haven't already bought them) to the 2930F they support 'software' stacking using VSF. You will still need physical connections between switches but no specialist stacking hardware.
