Campus Switching and Routing
2920 stacking
Can we stack 2920 24 port and 48 port POE switches. kindly let me know
Re: 2920 stacking
Hi m.asif,
Yes all 2920's can be stacked together using the appropriate stacking modules and cables.  The 2920 can be stacked up to 4 members in a ring or chain stack topology.
Let me know if you have more questions.
Justin
JUSTIN NOONAN
TECHNICAL MARKETING ENGINEER – ARUBA CAMPUS TECHNOLOGIES
O: +1 916 540 1748   |   justin.noonan@hpe.com
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
Re: 2920 stacking
Yes, The limit is 4 switches but they can be a combination of 24 port, 48 port, PoE or Non PoE.
Contributor I
Re: 2920 stacking
Yes, maximum stacking up to 4 switches, can be mixed as long as 2920 family and recommended using ring topology.
You can reference this document for further configuration
http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8156_wb_2926_atmg/content/ch06s02.html
