Campus Switching and Routing
2920f firmware question
Can you update an HP2920  (j9729a) switch with the Aruba 2920 (j9729a) firmware?
Re: 2920f firmware question
Yes, you can. They're the same switch, just new branding and new mobility-centric features.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
