Campus Switching and Routing
Contributor I
2930F Aruba AP profiling in 16.5.x SW
Hi
I am implementing a network with 802.1x on the ports, on the switches i will have ports used for Aruba AP and to make life easy i will use profiling
device-profile name ap
    untagged-vlan 110
    exit
device-profile type "aruba-ap"
    associate "ap"
    enable
    exit
When using authenticator on the ports, the port is closed until sone EAP traffic open the port therefor i use
aaa port-access use-lldp-data
to get LLDP into a "Closed" port. This works but then
802.1x stops working, and when removed 802.1x works again but the profiling stops working
aaa port-access authenticator 1/1-1/48,2/1-2/48
aaa port-access authenticator 1/1-1/48,2/1-2/48 client-limit 10
aaa port-access authenticator active
Am i missing som command to have both functions working
or is this the design??
Running 16.5.0009 (due to other issues) Tried 16.6 same issue.
Re: 2930F Aruba AP profiling in 16.5.x SW
Greetings!
There is an additional command that is specific to Aruba APs that may help:
switch(config)# aaa port-access lldp-bypass help
Usage:   [no] aaa port-access lldp-bypass <PORT-LIST>
Description: Configure lldp-bypass on the switch ports
to bypass authentication for Aruba-APs that sends a
special LLDP TLV. When lldp-bypass is enabled on the switch ports then
Aruba-APs connected to that port will not undergo any
authentication like 802.1x/WMA/LMA. By default,
lldp-bypass is disabled on the switch ports.
Try enabling that and see if it solves your issue.
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
Contributor I
Thanks for the suggestion.
Yes this "opens" the port for LLDP so profiling occours, BUT stops 802.1x
Tried that enabled stops 802.1x, disabled 802.1 works
