Campus Switching and Routing
2930F Tunnel Node and Airwave
Hello All,
I am configuring Tunnel Node between 2930F and 7030 Controller.
This is for the purposes of forwarding DPI packet info to Airwave, much like APP RF.  The Controller is added in to Airwave
The first question:  Is this the right way to do it?  Or will adding the 2930 direct in to Airwave, and using AMON data be the answer?
Secondly:  on the 2930, I cannot add a client access port on VLAN 1 (which is the Customer's native desktop VLAN) in to the Tunnel node to Controller, because, as you would expect the VLAN 1 has the Management IP address for the Switch.
Is this correct?
Thank you
Andy
Re: 2930F Tunnel Node and Airwave
Hi Andrew,
Currently, in Airwave, you can see the client attached to the switch, and the client details in AppRF.  You can also glean this information from the controller.
Attached are screenshots from my lab setup showing what is visible from a tunneled client standpoint in Airwave and AppRF.
There is quite a bit of work and investigation being done to enhance this in Airwave.
As to the second point, if you're using  VLAN 1 for management traffic, you will indeed need a separate VLAN for tunneled client traffic.
Justin
