Campus Switching and Routing
2930F VSF Ring Topology
Can anybody tell me how to setup a vsf ring topology? The VSF configuration guide has only the VSF chain topology.
There are 4 members in the vsf stack.
Thanks.
Re: 2930F VSF Ring Topology
Yep. Page 636 of the HPE ArubaOS-Switch Management and Configuration Guide.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Page 598 to 649 is all about VSF.
Cheers
James
Thanks! This worked for me!
