Campus Switching and Routing
Occasional Contributor I
2930F VSF
Hello Everyone,
I am trying to perform VRF on Aruba 2930F.
However Iam getting the following error.
VSF port failure on link 1 port 1/51:
Peer port 52 is not VSF enabled
ST1-CMDR: VSF port 1/51 is in error state
----  Bottom of Log : Events Listed = 255  ----
Can you provide an solution for the same. Thanks in advance.
Re: 2930F VSF
Greetings!
What version of software are you running on each 2930F?  Also, is there an existing configuration on the switch you're trying to add to the VSF fabric?
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
Re: 2930F VSF
Hi Mathew,
Thanks for your response.
This is the version WC.16.04.0008
There is no existing configuration on the switches.
Haresh Niwate
Re: 2930F VSF
Hello everyone,
I just performed reset on the second switch using the following commands and later vsf worked as expected.
reset system configuration
reload
Haresh Niwate
