Campus Switching and Routing
Occasional Contributor I
2930M Configuration
I have set my snmp string as well as my tacacs key on my new 2930M stack and would like to encrypt them so they are not visible to anyone who may login to the switch.  Is there a way to do this?  With all of my other Brocade switches I have this option.
Re: 2930M Configuration
Looks like this will do the trick.
encrypt-credentials
