Campus Switching and Routing
2930M user-role issue
Hey everyone,
We are evaluating some 2930M, and had a question that someone might be able to answer for me.
We are trying to use user-roles. We have that working to a point. The way we have it now, is clearpass returns the hpe: user-role vsa, and the switch accepts it very happily. This is assuming we have the vlan defined on the switch.
What I would like to do, is have clearpass assign the user-role AND the untagged VLAN. However, when I updated the enforcement profile with the vlan information, the switch complains that the user role is invalid.
Is this something that can be done, or is it a limitation?
To assist in explaining what I mean, here is the config for a user-role
User Role Information
Type : local
Reauthentication Period (seconds) : 64800
Untagged VLAN : 108
Tagged VLAN :
Captive Portal Profile :
Policy : Policy-Standard_Student
Tunnelednode Server Redirect : Disabled
Secondary Role Name :
When I remove the untagged VLAN, and add it to the enforcement profile in clearpass(screenshot attached), i get the user-role is invalid.
Any ideas?
Chris
Re: 2930M user-role issue
Did you follow the ClearPass Solution Guide for Wired Policy Enforcement?
Tim Cappalli | Aruba Security
I actually looked through it right before I posted, just to make sure. From what I saw, everything in there showed the user-role already having the VLAN defined if using local user roles.
I understand I could use downloadable user roles and assign a VLAN that way, however, my end goal is to have multiple devices having the same role, but different VLANs.
My use case being, we have different VLANs for a wide range of  devices, however, they all require a very similar set of ACLs.
The role should really be the security context and each role would have a VLAN attached. VLAN names are recommended to abstract the VLAN-ID across the environment from a policy standpoint
Examples:
STUDENT
vlan-name student
FACULTY
vlan-name faculty
STAFF
vlan-name staff
MEDIA-PLAYER
vlan-name headless
PRINTER
vlan-name headless
QUARANTINE
Vlan-name quarantine
PROFILE
vlan-name guest
GUEST-REG
vlan-name guest
GUEST
vlan-name guest
That makes sense. Thanks a ton for your clarification.
Examples:
STUDENT
vlan-name student
FACULTY
vlan-name faculty
STAFF
vlan-name staff
MEDIA-PLAYER
vlan-name headless
PRINTER
vlan-name headless
QUARANTINE
PROFILE
vlan-name guest
GUEST-REG
vlan-name guest
GUEST
vlan-name guest
Tim, do you have any suggestion for someone who wants the VLAN names to be unique to each VLAN ID?
For example I use a VLAN ID of 2314 for printers at one site and 2414 for printers at another.  Rather than calling both VLANs "PRINTERS", I like to name them uniquely to avoid any possible confusion, such as "SITEA_PRINTERS" and "SITEB_PRINTERS".
Is there any other soluton besides changing my naming convention to be more ambigious(IMO)?
It seems like it would work if there was a way to do VLAN translation (I'm thinking of IAP clusters, where I can pass the same VLAN name as a VSA for all sites, but translate it in each site's IAP to the correct VLAN ID).  However, I'm not seeing a way to do this with DURs on the switches.  Wanted to make sure I wasn't missing anything.
My next-best workaround (besides an insane amount of logic and additional enforcement profiles) is to use LURs and define the different VLANs within them on each switch.  For example on SITEA switch:
aaa authorization user-role name "PRINTERS"
reauth-period 86400
vlan-name "SITEA_PRINTERS"
exit
And on SITEB switch:
reauth-period 86400
vlan-name "SITEB_PRINTERS"
exit
That way I can just pass back PRINTERS as the HPE-User-Role to all sites.
Using switch-specific names completely defeats the point of using VLAN names and will make your ClearPass policy very complex.
Thanks so much for your prompt response!  I've always used VLAN names as an English version of the VLAN ID (coming from Cisco-land it was called a "description"), so this is a new concept I'll have to make peace with I guess (or cause myself some extra work).
I wish there was an extra description field where I could uniquely describe the VLAN in the switch config while still abstracting the name...that would make me feel better.  :-)
