Campus Switching and Routing
7005 Controller Licensing
I'm installing an Aruba 7005 that a client bought. This is my first foray into Aruba and as I understand it, separate licensing is required. What is the absolute minimum licensing required to get the controller running in standalone with 8 AP103s. SKU or part numbers are appreciated. Thank you.
Contributor I
Re: 7005 Controller Licensing
i think you will need 8qty of " LIC-AP" for you tk manage those APs. you can check the datasheet of Aruba 7005 and its ordering information for specifics.
#AirheadsMobile
Ideally, you’d want 8x LIC-ENT
Tim Cappalli | Aruba Security
LIC-ENT, not LIC-AP? What's the difference?
Contributor I
