Campus Switching and Routing
802.1x Authentication for Multi-domain on Aruba 2930M switch
Hi...
We have implemented .1x authentication for single domain on interface/port. it is working fine but we are looking for .1x authentication for Multi domain.
Example for single domain authentication..
aaa authentication port-access eap-radius authorized
aaa port-access authenticator 1/25 auth-vid 33
aaa port-access authenticator 1/25 unauth-vid 63
aaa port-access authenticator 1/25 client-limit 5
aaa port-access authenticator active
Could you please share the commamds for multi domain authentiaction.
Ping me on sandeep.dj@systemtech.biz
Re: 802.1x Authentication for Multi-domain on Aruba 2930M switch
Did you follow the ClearPass Solution Guide for Wired Policy Enforcement?
Tim Cappalli | Aruba Security
No.But we are using extrenal radius server.
Ok anyway i'll go through that guide and get back to you..
Thanks for your reply
Frequent Contributor I
Hi
If you mean by multidomain using different @domain and @domain2 within the authentication then that needs to be configured on the RADIUS side. Are you using ClearPass?
As Tim already suggested take a look at Tim's great guide!
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Can't we achive this @domain1 and @domain2 senario without Clearpass.
We are using External Radius server. Can i configure the user profile on radius server.
Hi
That’s depending on your radius server not the switch.
Which are you using?
Cheers, Frank
Radius is at Windows server 2012 R2.
Apoorv.
Setting up multidomain on NPS is maybe off topic here.
https://social.technet.microsoft.com/Forums/windowsserver/en-US/30715f28-26d0-43a8-840e-ef78cf54eaad/npsradius-authentication-from-mulitple-domains?forum=winserverNAP
hope it helps.
Cheers, Frank
