Campus Switching and Routing
8400 Feature Detail
Hi Guys,
Im looking for some resource that gives me a a more in depth explanation of some of the features provied by the 8400. More than what is provided by the datasheets. Is there any other guides, maybe a config guide that i can refer too?
Also, does anyone know if firware updates are fully in service or if there is downtime? I can see that individual modules can be upgraded.
Re: 8400 Feature Detail
Hi, it's probably the best if you contact an Aruba SE in your region. Let me know if you need support with a contact person.
