Campus Switching and Routing
AAA/NAC Comware v7 Feedback
Here some feedbacks with AAA/NAC features on Comware V7 (5130/5510HI/etc..)
Hope it will help !
Serge
Contributor I
Re: AAA/NAC Comware v7 Feedback
Hello Serge,
On page 15 there is a diagram with all the features.
I have 5510 switches and 5400. And for the 5400 i also use dynamic ACL.
On this page it says that on the 5130 and 5510 also dynamic ACL are supported.
Do you have an example of how to do this in clearpass for the 5510.
Already my thanks.
Aruba ACCX #749, ACDX #793, ACMP, ACEAP | HPE Master AS
contact: thierry.lubbers@axez.nl
You should use the standard Radius « Filter-Id » Attribute (11)
And define the value as the ACL number you want to apply on the authenticated port.
Or
Use the user-profile feature. In the case, set user-profile name as standard Radius Filter-id attribute (11)
User-profile test
     qos apply policy test inbound
acl number 3000
 rule 0 permit tcp source-port eq 21
traffic classifier classifier_1
if-match acl 3000
traffic behavior behavior_1
 filter deny
qos policy test
  classifier classifier_1 behavior behavior_1
User-profile test enable
Regards
Contributor I
Thanks for the quick replay,
I will test it.
Good document by the way.
Keep it coming
