Campus Switching and Routing
Occasional Contributor I
AP port config for Cisco switches
When hooking up an Aruba Access Point to a cisco switch what port configurations should be set on the cisco switch?
Aruba
Re: AP port config for Cisco switches
802.3af Power Over Ethernet (PoE) = enabled :)
Other than that...  if the Aruba AP is in tunnel mode, then the switchport should be in standard access mode with a single VLAN.
If the Aruba AP is in bridge mode, then the switchport should be in standard trunk mode, with multiple VLANs corresponding to the networks to be bridged.
