Campus Switching and Routing
Access OSPF 2930F
I noticed in the datasheet that Access OSPF is a feature but can't see any more info on it. Cisco seem to define this feature as the switch can belong to a single instance and support 200 learned routes. I wondered what HPE Aruba supported?
Graeme
#AirheadsMobile
Re: Access OSPF 2930F
Hi Graeme,
Here is our definition of OSPF Routed Access from the WC switch SW Release Notes.  (WC.16.02.0012 notes attached, see page 10)
OSPF Routed Access Support is new and different from the OSPF support historically seen on the K, KA, and KB platforms.
From 16.02.0008 onwards, OSPF Routed Access support is enabled on WB and WC platforms with the following limitations:
• Only one area is allowed for both OSPFv2 and OSPFv3
• Same area ID should be used for OSPFv2 and OSPFv3
• Maximum of 8 OSPF interfaces supported for each OSPFv2 and OSPFv3
• ABR configuration and Virtual-links are not supported
• Max supported routes: 200 for each OSPFv2 and OSPFv3
• OSPFv3 tunnels and BFD are not supported.
Cheers,
-Scott
Scott Koster | Technical Marketing Engineer, Campus Switching Solutions
Aruba, a Hewlett Packard Enterprise Company
Cheers Scott
Occasional Contributor I
Digging out this old thread after throwing a 2930F into my ospf net with >600 Routes.
The switch did not give me any indication of the limitation of 200 OSPF routes. It shows
r-2930f-1# show ipv6 route summary
IPv6 Route Table Summary
Protocol Active Routes
Connected 1023
OSPF3_Internal 22
OSPF3_ASE 1182
Also, looking at the advertised prefixes on another router, I did not see that limitation:
stephan@r-nan-1> show route protocol ospf3 | match {link_local_addr} | count
Count: 511 lines
The count shows all 511 advertised prefixes on 511 vlans with an ipv6 address. (the 512th is for the ospf interface).
Did that limitation get lifted, or is it doing a software-fallback (without letitng me know)? This would be good to know, since I am evaluating these switches, and not having this limitation makes it much more attractive compared to competitor's devices.
Switch software: WC.16.05.0007
I::IPv6
