Campus Switching and Routing
Active stack switch vty/console
How on the love of god can we see on which switch we are logged using the serial console ?
PCT00C02S06(config)# show stacking
Stack ID : 00017010-6f8f2a00
MAC Address : 70106f-8f2a45
Stack Topology : Ring
Stack Status : Active
Split Policy : One-Fragment-Up
Uptime : 0d 18h 47m
Software Version : KB.16.01.0004
Mbr
ID Mac Address Model Pri Status
1 70106f-8f2a00 Aruba JL074A 3810M-48G-PoE+-1-slot ... 255 Commander
2 70106f-8f8600 Aruba JL074A 3810M-48G-PoE+-1-slot ... 200 Standby
Cisco example:
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48P 12.2(35)SE5 C3750-IPBASE-M
2 52 WS-C3750-48P 12.2(35)SE5 C3750-IPBASE-M
Re: Active stack switch vty/console
Hi Victor,
I'm checking on the release notes to find out when, but that feature has been added recently.  I'm running 16.02.0010 on my switches in my lab and it shows which switch I'm logged into.  Is it feasible for you to upgrade to newer firmware?
Justin
JUSTIN NOONAN
TECHNICAL MARKETING ENGINEER – ARUBA CAMPUS TECHNOLOGIES
O: +1 916 540 1748   |   justin.noonan@hpe.com
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
Many thanks :) upgraded and now I have the info I needed.
Mbr
*2 70106f-8f8600 Aruba JL074A 3810M-48G-PoE+-1-slot ... 200 Standby
