Campus Switching and Routing
After reboot switch uses backup tunneled node IP
Dear Community
I have a setup with 2930F switches and AOS 8.2.1 WLC (no clustering) with MM. I use PUTN and downloadable user-roles.
Everything works fine but whenever a switch is rebooted it uses the backup-controller to build the tunnel.
Does somebody know why? From my understandig the switch should use the primary controller-ip whenever it's reachable.
tunneled-node-server
 controller-ip 10.50.10.254
 backup-controller-ip 10.40.10.254
 keepalive interval 1
 mode role-based
 enable
Best Regards
Marc
Re: After reboot switch uses backup tunneled node IP
Marc,
Can you please also provide your AOS controller configs?  I agree, the backup connection after a reboot should not happen.  Have you adjusted the keepalive interval to 8 seconds (default) or greater?
Rob
ROB HAVILAND
DIRECTOR TME, ARUBA WIRED INTELLIGENT EDGE
M: 414.841.3605 | rob.a.haviland@hpe.com
8000 FOOTHILLS BLVD | ROSEVILLE, CA 95747 USA
Hi Marc,
I'm seeing the same behavior in my lab setup.  It appears that the "operational roles" switch when the switch is rebooted:
Dyn-Seg-Demo(tunneled-node-server)# show tunneled-node-server state
Local Master Server (LMS) State
LMS Type IP Address State Capability Role
Primary : 10.1.1.31 Complete Per User Operational Primary
Secondary : 10.1.1.32 Complete Per User Operational Secondary
Switch Anchor Controller (SAC) State
IP Address Mac Address State
SAC : 10.1.1.31 000c29-25137b Registered
User Anchor Controller (UAC) : 10.1.1.31
User Port VLAN State Bucket ID
Dyn-Seg-Demo(config)# show tunneled-node-server state
Primary : 10.1.1.31 Complete Per User Operational Secondary
Secondary : 10.1.1.32 Complete Per User Operational Primary
SAC : 10.1.1.32 000c29-071ba0 Registered
User Anchor Controller (UAC) : 10.1.1.32
I will get this in to R&D to be fixed.  The switch should reach out to the primary controller after a reboot first.
A workaround to reset is to disable the tunneled-node-server command:
Dyn-Seg-Demo(tunneled-node-server)# no enable
Dyn-Seg-Demo(tunneled-node-server)# enable
Justin
JUSTIN NOONAN
TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
O: +1 916 540 1748   |   justin.noonan@hpe.com
Hi Justin
Thank you for your feedback. Allright, can you already say when this is fixed or by what version?
Best Regards
Marc
Hi Marc,
R&D is still investigating and prioritizing as to when it would be implemented into a future software update.
Justin
