Campus Switching and Routing
Airwave - How to add a stack of 2920 switches
Hi all,
Have some spare Airwave licences so was trying out Airwave management/monitoring of 2920s running the latest Aruba-branded firmware.  Works well!
Now, in production we have stacks, not individual switches and this is where by problems start.  With the individual switches I was manually adding them in Airwave and it was detecting the correct template for the switch.  With the stacks I just can't get it to detect anything and I don't know how to manually map atemplate to a device.
I just get a device added that is always down and config is never collected.
Any tips or suggestions please?
Thanks a lot.
PS: Airwave - HPE_ArubaOS on switches WB.16.04.0008
Contributor I
Re: Airwave - How to add a stack of 2920 switches
Hi Toby,
This should be simular as adding a normal switch. Aruba has optimed switch management in the latest AirWave firmwares. I will advise to upgrade AirWave to the latest firmware (
Are you sure SNMP configured correctly (and allowed in the firewall(s)? Normally a device should up if ping is allowed and also if the device type is unknown. I think the traffic is not allowed from AirWave to the switches.
Willem Bargeman
ACCX #822 | ACMP
Thanks Willem.
Having looked into it deeper it does appear to be an issue with traffic between AirWave and the switch stack - rather than a problem with AirWave or my process.
