Campus Switching and Routing
Aruba 2530 - All ACT LED constantly lit
Hi guys, can anyone help me explain this issue?!
When I connect a small unmanaged switch to my Aruba 2530-48G, the mode LED's on all ports switch from blinking to being constantly lit. The mode ports are set to default Activity (Act).
I cannot find any documentation as to what this means nor error messages in the switch. A readout of the port is enclosed below and I can see Collisions etc.
Any suggestions to what this means?
BR Bertrand
 All Act LED constantly lit
Re: Aruba 2530 - All ACT LED constantly lit
From your messages it's not clear if you connect it with one or multiple cables? I've almost a feeling you connect multiple cables from unmanaged switch to 2530. If so this means you're creating a loop. This will probably explain why probably all led blinks.
