Campus Switching and Routing
Super Contributor II
Aruba 2530 NTP issues
Hi all,
looking for some guidance.
have configured a pair fo 2530s to talk NTP to windows server and the status is showing config , insane and the ntp server is not ever going into sync.
show ntp status
NTP Status Information
NTP Status : Enabled NTP Mode : Unicast
Synchronization Status : Not Synced Peer Dispersion : 0.00000 sec
Stratum Number : 16 Leap Direction : 0
Reference Assoc ID : 0 Clock Offset : 0.00000 sec
Reference ID : 0.0.0.0 Root Delay : 0.00000 sec
Precision : 2**-18 Root Dispersion : 0.08570 sec
NTP Up Time : 0d 1h 35m Time Resolution : 1270 nsec
Drift : 0.00000 sec/sec
System Time : Mon May 15 15:44:22 2017
Reference Time : Mon Jan 1 11:00:00 1990
IP Address : 10.10.4.10 Peer Mode : Server
Status : Config,Insane Peer Poll Intvl : 6
Stratum : 1 Root Delay : 0.00000 sec
Ref Assoc ID : 1 Root Dispersion : 10.54242 sec
Assoc Name : NTP Association 1 Reach : 37777777777
Reference ID : 76.79.67.76 Delay : 0.00603 sec
Our Mode : Client Offset : -10.05123 sec
Our Poll Intvl : 6 Precision : 2**-23
Dispersion : 0.02230 sec
Association In Packets : 74
Association Out Packets : 74
Association Error Packets : 0
Origin Time : Mon May 15 15:44:14 2017
Receive Time : Mon May 15 15:44:24 2017
Transmit Time : Mon May 15 15:44:24 2017
Filter Delay = 0.0064 0.0084 0.0111 0.0068 0.0094 0.0060 0.0116 0.8501
Filter Offset = -10.0358 -10.0384 -10.0430 -10.0452 -10.0481 -10.0512
-10.0524 -9.6364
IP Address : 10.10.5.10 Peer Mode : Server
Stratum : 2 Root Delay : 0.00175 sec
Ref Assoc ID : 2 Root Dispersion : 10.56506 sec
Assoc Name : NTP Association 2 Reach : 37777777777
Reference ID : 10.10.4.10 Delay : 0.00579 sec
Our Mode : Client Offset : -10.05795 sec
Dispersion : 0.03462 sec
Origin Time : Mon May 15 15:43:34 2017
Receive Time : Mon May 15 15:43:44 2017
Transmit Time : Mon May 15 15:43:44 2017
Filter Delay = 0.0065 0.0065 0.0136 0.0063 0.0063 0.0059 0.0086 0.0058
Filter Offset = -10.0372 -10.0401 -10.0399 -10.0456 -10.0486 -10.0515
-10.0550 -10.0579
Here is my config:
timesync ntp
no sntp
ntp unicast
ntp server 10.10.4.10 iburst
ntp server 10.10.5.10 iburst
ntp enable
time daylight-time-rule user-defined begin-date 10/01 end-date 04/01
time timezone 600
NTP Server is windows DC.
Any ideas?
Scott
Re: Aruba 2530 NTP issues
Hi Scott,
Can you provide some more details on the NTP server? What version of windows are you using maybe add even output of following command  w32tm /query /configuration when it's standalone NTP server.
Thanks in advance!
Hi Dobias,
Its Win 2016 Server. Unfortunately i had to move on and no longer have access to the environment. The switches have been configured to talk to an external NTP server now.
When i get some time i'll try and lab this up again.
Scott
Hi Scott,
No problem and let me know whenever I can support you.
Regards, Dobias
Hello! Did you resolve this issue? Because I have the same problem, with my Aruba 3800 switch. So it's not synchronize with my NTP server. When I listed syslog, it shows this: " ntp: ST1-CMDR: The NTP Server *ip_address* is unreachable." But ping is working greate. Other HPE switches in network synchronize with this NTP server without problem.
unfortunately i had to move on before being able to troubleshoot any further.
Hi Dobias!
Maby you can help me? Thnx.
I can at leat try 8-)
Can you forward me the NTP configuration of the switch and if possible add IP information and some details of NTP server?
Did anyone ever resolve this issue?
I have the same problem on my Aruba 2530, im running my WatchGuard Router as the NTP Server, all other devices can use the WatchGuard as the NTP server except the Aruba.
I can see network traffic passing through from the switch to the router, i can ping it etc... i just get a returned error in the logging of the Aruba saying it was unreachable.
As a test are you able to confirm an external NTP server on the switch, does this work? Have you tried manually sync'ing the clock to the same time/date on the NTP and then tried configuring the NTP server again? I've seen issues where if the difference is too great between the device and the NTP server it will not sync? Also, don't forget to check the NTP versions you have configured.
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
