Campus Switching and Routing
Aruba 2930F and VSF
Good day,
I'm sure this has been answered before but I just need to make sure my setup will work.
Switch 1 (2930f) - VSF -  Switch 2 (2930f)
Switch 3 (2530) ether 47 to Switch 1 ether 1 - Switch 3 (2530) ether 48 to Switch 2 ether 1
Switch 4 (2530) ether 47 to Switch 1 ether 2 - Switch 3 (2530) ether 48 to Switch 2 ether 2
What is the best setup for the 2530 to work in this design
Re: Aruba 2930F and VSF
Hi Wayne,
That will work.  I would recommend using an LACP link aggregation group between both vsf members to the 2530 for redundancy.
VSF side:
trunk 1/1,2/1 trk1 lacp
2530 side:
trunk 47-48 trk1 lacp
Justin
