Campus Switching and Routing
Occasional Contributor I
Aruba 2930F
In Aruba 2930 Dhcp config, is it possible to assign particular IP to a particular MAC.
If it is yes how to execute the same....?
Re: Aruba 2930F
This is based on the 16.04 code but try the following :
static-bind ip<IP-ADDR/MASK-LENGTH> mac <MAC-ADDR>
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
