Campus Switching and Routing
Occasional Contributor I
Re: Aruba 5400 VRRP Help require
Thank you Patel.
As i will implement this configuration today i will let you know. i will also try to upgrade IOS. In my network, we only need redundancy now so that access switches should communicate to each other in case of primary Core goes down.
No there is no specific reason to run RSTP, as i said i only need redundancy wehther from RSTP or MSTP.
Hi Zubair,
For redundancy with 5400, you can use VRRP or VSF. VSF is Aruba "stack technology". With it, you delete STP problem and provide LACP link. In your configuration, with VSF all your VRRP IP will be the only VLAN IP interface.
