Campus Switching and Routing
Aruba 5400R zl2 Switch v2 to v3 Modules Upgrade
Hi All,
The Aruba 5400R zl2 v3 Modules are 10 new next generation campus L3 full featured ProVision modules for the Aruba 5400R Switch Series. The 6th Generation HP Networking ASIC offers enhanced fully flexible OpenFlow and SDN capabilities, programmability, improved speed/per slot bandwidth. They provide 10GBase-T features and including Aruba Smart Rate: 1G/2.5G/5G /10G Copper PoE+ multi -rate ports with MACsec.
The following guide indicates the high level approach for migrating customers migrating from v2 to v3 modules on the Aruba 5400R Switch.
Aruba 5400R zl2 v2 to v3 Modules Upgrade
NOTE: HP Provision OS switches are now Aruba OS switches.
Jay
Re: Aruba 5400R zl2 Switch v2 to v3 Modules Upgrade
Document Attached
