Campus Switching and Routing
Contributor II
Aruba HPE Switching Stencils
Hi All,
Does anyone know where the updated stencils are for 5412 switches & Aruba 2930F switches?
I had a look around on google, but couldn't find the specific ones or if you could advise me of the closest ones to use please?
Re: Aruba HPE Switching Stencils
You can get stencils in the following locations:
http://www.arubanetworks.com/assets/Visios.zip
https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/1649/Default.aspx
http://www.visiocafe.com/downloads/hp/HPE-Networking.zip
I'm not sure how up to date they are though.
Cheers
James
Contributor II
Unfortuently, this does not have the exact stencil I am looking for, which is Aruba 5412R 92GT PoE+/4SFP+ v3 zl2 Swch.
I did see these links before  I made the post, just was wondering if anyone actually came across this stencil.
Regular Contributor I
Me to.
