Campus Switching and Routing
Aruba LACP algorithm recommendation
What is the recommended LACP load balancing algorithm (from the switch perspective) for both Aruba Controllers and APs?
I have enabled LACP and configured some APs, however I have taken a guess as to what algorithm to use.
I am using Dell PowerConnect swiches, so I have the following options available:
1 - Src MAC, VLAN, EtherType, Src module and portId.
2 - Dest MAC, VLAN, EtherType, Src module and portId.
3 - Src IP and Src TCP/UDP port.
4 - Dest IP and dest TCP/UDP port.
5 - Src/Dest MAC, VLAN, EtherType, Src MODID/port.
6 - Src/Dest IP and Src/Dest TCP/UDP port.
7 - Enhanced hashing mode.
Currently I have the following algorithms set:
Switch -> AP225 = 6 - Src/Dest IP and Src/Dest TCP/UDP port.
Switch -> W-7210 = 6 - Src/Dest IP and Src/Dest TCP/UDP port.
Re: Aruba LACP algorithm recommendation
Does anyone know the LAG recommendations from Aruba?
