Campus Switching and Routing
Contributor I
Aruba Licensing
Hi All,
I do not know if this section is correct one for my case
When I try to register my Clear license I got attached error
and when I try to press Home link it keep prompt same error message
Please your advice
Re: Aruba Licensing
I don't think you can use a free email service to sign up for licensing....  Do you have an email address from your organization?
Contributor I
Re: Aruba Licensing
Yes I have, but I already tie the mobility controller license successfully before with same Email address
Any way I will re-attach the controller license to my company Email address, and register the CPPM license to it too. will update for knowledge share
Contributor I
Re: Aruba Licensing
Hello Colin
You are right, it register successfully with offical Email, and I was registered my mobility controller's license with same offical one.
Thank you,
