Campus Switching and Routing
Contributor I
Aruba OS switch Aruba vpn 문의
안녕하세요!
Aruba OS Switch에서 aruba-vpn이 지원을 하고 있습니다.
aruba-vpn type에 amp로 airwave와 연동하는것으로 나와있습니다.
궁금한점은
1. aruba-vpn이 IPSEC VPN을 의미하는 것인지와
2. aruba-vpn을 이용하여 Aruba OS switch들간에 연동이 가능한지
   궁금합니다.  감사합니다.
Hello!
Aruba-vpn supports on Aruba OS Switch.
The aruba-vpn type is shown as an amp that works with airwave.
The questions are as follows
1. Does aruba-vpn mean IPSEC VPN?
2. Is it possible to interwork between Aruba OS switches using aruba-vpn?
   Thank you.
Aruba_vpn.jpgaurba-vpn config
Regular Contributor I
Re: Aruba OS switch Aruba vpn 문의
Please ask your question in English.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Contributor I
hello!
I added the question in English.
Thanks!
Occasional Contributor I
RE: Aruba OS switch Aruba vpn 문의
안녕하세요,
aruba-vpn 은 메뉴얼에 나온 아래의 3가지 경우에 사용되는 것 같습니다.
   --> ipsec vpn
   --> ArubaOS switches <-> Aruba controller (ipsec)
   --> ArubaOS switches <-> Airwave server (ipsec)
   --> ArubaOS switches <-> ArubaOS switches (X)
Hi
The ArubaOS SW is only able to do a IPSEC VPN for management traffic (airwave, central), not for user traffic. The hardware is not capable to do so. There is no encryption hardware is the switch.
Hope this helps
Cheers, Frank
